How to do a glow behind image ?
Sunsparkle
Version de PhotoFiltre : 9.0.0
Système d'exploitation : Windows ME
Message par Sunsparkle »
Hi, Im new to forums like this so excuse me if I don't get it quite right. But I saw the voting poll and as I'm interested to learn all I can I put "all the above", but the main thing at the moment is a glow behind image sort of effect and a brilliant white type text effect. If someone could please help me with these, I'd be very grateful.
~Sunsparkle~
PaulR
Message par PaulR »
You could use the 'progressive contour' filter and check the 'outside' option - look at the text in this thread..
viewtopic.php?t=10715
Hi Sunsparkle,
I think PaulR did not know that his original topic was moved in international part of forum :
viewtopic.php?t=10357
You can also find some tutos on the web site of Bill => post above
The last one in french section with an automatic Google translation :
http://translate.google.com/translate?h ... u_imp.html
:arrow: This type of question would be posted in Graphical support .
I will move it after you will read this post.
Jaume44
Système d'exploitation : w7
Bright
Message par Jaume44 »
Sunsparkle, how are you? Welcome to the forum. I see you have PFS, so you are layer capable. One quick manner to achieve a glowy back to an object would be using the retouch tool on Gamma+ on the background behind the object. You may want to experiment with the pressure before doing your final attempt. The object must be a seperate layer. As for bright text, you could also use the same tool at the same setting to highlight white text. I have had great results in placing the text as white text, then converting the text layer to an image layer. Use the selection wand on color and select the text. Now use your progressive contour plugin under Filter < Stylize. Depending on how large the text is will determine how many pixels the progressive contour should be...choose black at first. When you have done this then use that retouch wand (tool). I hope this has been helpful. \:D/
There are also 8bf plugins for lighting effects.
Sunsparkle
Thanks to all
Thanks for the tips and help everyone has given me. It's all so interesting, I already feel welcome and I've not been here long :)
~Sunsparkle~
