PC crash at big pictures
Andreas
Message par Andreas »
Hi,
does anybody have the same problem?
While working on pics which have more than 2 MB, Photofiltre crashes.
I have big issues with pictures, which are large sized.
Regards
Andreas
Which OS are you running ?
Andreas
Win 98 SE
Win 98 SE
So the problem is not the "weight" of files but their dimensions. The images you are talking about may be larger than 2048x1536, and Windows 9x doens't like it at all :?
So there is no solution :cry:
Andreas
Many thanks for your help !!
