please help
Oskala
please help
Message par Oskala »
hello. my english is bad, but anyway. i have a problem with both pf and pfs. for example. when i click on the "about photofiltre" there's no text just the area where the text should be. sometimes icons is missing, there's just this empy window where all the text and images should be, but simply isn't there. i have only had this problem with the new versions.
i don't know why all the graphics isn't showing. is it my computer or the program(s) that is the trouble? i haven't got any problems using other programs
hope you'll understand my problem. it's not that easy to explain in a language that you don't speak that often :roll: [/img]
Oskala
this is what it looks like:
carlo taradel
Version de PhotoFiltre : PF-PFS
Système d'exploitation : win XP pro- ubuntu_ breeze
Processeur : recycled from waste bin
Mémoire RAM : 1026
Message par carlo taradel »
i can't see it :!:
