Regarding the Contact Sheet, I have the following suggestions:
1) Have option to hide the file extension from the file name.
2) At present, if I set up to have 12 columns by 8 rows, the contact sheet is blindly created that way.... irrespective of the actual paper size. This then causes problems while printing. Will it be possible to have an option where the user defines the paper size and based on that and the picture size chosen, the number of allowable rows and columns are set.
It would be also be nice if for eg. the user chooses A4size paper and chooses 2 columns x 2 rows, there is a check mark to "stretch picture propotionately". This will then have the 4 pictures at its maximum size within the A4 size paper keeping a specified margin between the pictures.
3) A third request in this connection would be for an option to repeat a picture multiple times in a contact sheet. Sometimes, I want to print just 1 picture, but I want to have 4 copies on 1 page to save paper. It would then be nice if the user could Choose A4 and the Landscape / portrait and then choose the picture to print and then specify "no. of times to duplicate" and finally whether to "stretch picture propotionately" or not.
4) Use photmasque style.
Hope this is possible!
Cheers
Contact sheet
JogyGeorge
- Habitué(e)|Habitué|Habituée
- Version de PhotoFiltre : 6.2.0
- Processeur : 2.4Ghz
- Mémoire RAM : 256
