Carole Alexander
Messages : 28 Inscription : 10 déc. 2005 10:36
Système d'exploitation : Windows XP Home
Message
par Carole Alexander » 09 févr. 2006 22:35
Hi All
I'm having problems trying to put a photo of a rose onto my website.
I took the photo on a white background but when I uploaded it to my website the background color looks grey.
I want only the rose to be visible (not the background of the photo).
Does anyone know how I do this
Thanks.
Carole
[Tom]I move the topic from Support graphique to Support/Elteno[/Tom]
nimitz
Messages : 906 Inscription : 03 sept. 2004 11:17
Version de PhotoFiltre : PF 6.3.0 Beta
Processeur : Pentium IV 3.2Ghz
Mémoire RAM : 512 Mo
Message
par nimitz » 10 févr. 2006 7:52
If i well understand your problem, you have to set your background transparent :
Image/Transparent color then clic on your background to select the color your want and use tolerance for it to be better.
The program tells you that adding transparency will decrease color number to 256 : it's normal
That's all
Carole Alexander
Message
par Carole Alexander » 10 févr. 2006 14:11
Thank you
It works.
Carole
nimitz
Message
par nimitz » 10 févr. 2006 14:15
Nice!!!
Have fun
