How do I get photos vertically (not horizontally) together
Carole Alexander
Système d'exploitation : Windows XP Home
Message par Carole Alexander »
Thanks to this Forum I now know how to put photos next to each other
and used this information to make a heading for my website.
I now need to put photos together vertically under my nav bar.
Any ideas on how I can do this :?:
Thanks
Carole
[Tom] I tag in [Ref] Reference or recommandation for research [/Tom]
Bill
Version de PhotoFiltre : Free and Studio
Système d'exploitation : Coffee
Processeur : God Given Brain
Mémoire RAM : Not as well as when I was younger
Message par Bill »
Carole:
I'm not sure which version of PhotoFiltre you have.
If it's the regular version open up a new image larger than your final image will be.
1) Copy and paste your first image into the new composition. When you do you will see dashed lines around the image. If you put your mouse in the center and left click you can move the image to wherever you want.
Move the image to the top left corner. Now move your mouse to the bottom right corner, Hold the "Shift Key", left click your mouse and resize the image to the size you want. You can see the actual dimensions along the bottom as you resize it.
2) When you have the image to the size you want, right click and choose validate.
3) Now follow that same procedure again, position the image below the 1st one, resize and validate.
4) When you have all the images you want in your composition, choose the rectangle Selection Tool, Draw a selection around what ypou want for your final composition and then go to : Image / Crop.
If you are using Studio just resize the layers as you add the images, merge them all together and then crop.
Carole Alexander
Thank you very much Bill :D
I'll try it out and let you know how I get on.
Cheers
Carole
