photofiltre & bartpe
I have installed photofiltre on bartpe bat it doesn't work.... any suggestion?
- Membre d'honneur
bart pre-installed enviroment, a special live cd with windows xp: you can boot xp from this cd on every pc (usually useful to repair pc with broken hdd or windows not working).... there are a lot of plug-in for most common software (i.e. nero, openoffice ecc.) and also there is a plugin for photofiltre but it doesn't seems to work....
- Membre d'honneur
PF can be added to the original barpe cd using the plug-in system: you install PF on your pc then copy all files on barpe installation directory then burn bartpe cd; PF should load from bartpe but this doesn't appens. PF files are present on bartpe cd but PF don't load, if you boot your standard xp from your pc and then launch PF from burned pe cd it run without problem....
- Membre d'honneur
