http://sourceforge.net/project/showfile ... _id=148727
Ignore this if you already have an aggregator or if you do not have Outlook.
This software is free, and it helps to avoid a lot of surfing. What to do with it?
Download it.
Install it.
Any time you are on a page that interests you, and you see either XML or RSS symbols, simply right click on the symbol and select “add to Blogbot.” You will receive information related to that page in an Outlook folder. It saves lots of time. I hope this is helpful for you.
Jack D. Rook – PhotoFiltre 6.1 and Studio user………….
Bien Utile - Very Useful
Jaume44
- Version de PhotoFiltre : Studio 10
- Système d'exploitation : w7
- Processeur : Pentium (R) Dual Core
- Mémoire RAM : 4 GB
