Plugin Engraving - > V2.0 to be tested
- Version de PhotoFiltre : 6
Hi all,
A new very altered version of engraving
- Light modification and improvement of the existing functions
- 2 new functions
- French/English
- Safeguard config
=> On the site
A+
- 2 new functions
- French/English
- Safeguard config
=> On the site
A+
- Version de PhotoFiltre : Free and Studio
- Système d'exploitation : Coffee
- Processeur : God Given Brain
- Mémoire RAM : Not as well as when I was younger
Wow!
Wow PF I love the Coal feature. This would be great for making Cave Paintings
Real nice improvement, the only problem is some of my tutorials will not be up to date anymore
- Version de PhotoFiltre : PF-PFS
- Système d'exploitation : win XP pro- ubuntu_ breeze
- Processeur : recycled from waste bin
- Mémoire RAM : 1026
Engraving...Please a link to download the old version!
I tried the new version with several (low and high res )images but it seem to me that FOR MY KIND OF USE
i will like to know:
1)
2)IF there is a way (
for PF:
since the previous Gravure is not anymore available on my copy of PF and PFS i could not make a accurate comparison
...but with the old one i always got good result,with the new one that kind of manipolation i spoke about usually didn't work so well.
At soon i can get a way to download the old one i will put on PF and, using the new one on PFS i will do a better check (using the same images)
- Version de PhotoFiltre : Studio 10
- Système d'exploitation : w7
- Processeur : Pentium (R) Dual Core
- Mémoire RAM : 4 GB
Gravure
I believe I have a copy of the older GRAVURE on my PF, which I have kept active because I like it a lot. Would you like it emailed to you. It says it is the version for PF, and it does not mention Studio.
If I may be of any help. I am yours truly, Jack
P.S. I just checked, I have both.
Hi carlo taradel,
Sorry, I have just seen your post
Which is exactly the function (or them) functions which change.
I can make a corrective measure or a new function.
I think of knowing why !!
Can you give precise explanations (images to illustrate for example)
Old Version (Compatible studio) :Here
A+
A+
.Which is exactly the function (or them) functions which change
I have to check it better but it is seems to me that outline works in a different way (more colours and usually no any pure black,...this could be a nice improvement,but not for my pourpose)
Missplaced
(I had put this post in the wrong category)
Folks, do not do what I did. I thought I had the latest engrave plugin in my new Studio version, but noooooooooo. I had the old one. I just test flew the new engrave plugin, and it is fantastic. Don't miss out on it.
Thank you AGAIN pf.
Thank you AGAIN pf.
In some images using it increase a lot the" pixelation"(not only increase the size but make them more visible) but i supposed there is no much to do about...
and ,back to the point newer didn't seem to enhance pixel more then older.
