Have or could someone translate
the "Diffusion B&W" plugin
and the "Gravure" plugin into english ?
Or, at least, is there , or could someone please wrote,
an how to or an documentation of this plugins ?
e.g.
Button [xyz] means this .xxxxx... in english and is for this ...yyyyy.. good for.
thanks
mercie beaucoup
Stefan
Request to translate "Diffusion B&W" + "G
- Version de PhotoFiltre : 6.1.2
- Système d'exploitation : W2k
- Processeur : 300 Celery@450
- Mémoire RAM : 768
- Membre d'honneur
La traduction ne presente pas de problemes insurmontables mais il faut modifier tous le code (pas prévus au départ)......FrançoisL a écrit :.....Pf, tu n'avais pas envisagé de traduire tes plugins ? Si oui ça en est où ?
Mais depuis le temps qu'on me pousse........
Je vais tacher de faire ca cette semaine
Mais le txt restera en Francais, sauf traducteur meilleur que moi... (pas dur !!)
A+
- Membre d'honneur
- Mémoire RAM : 768
- Mémoire RAM : 768
Thanks for your help!
As i said,
maybe an "how to.txt" what botton is for what
and a few examples to understand
would be enought ?
To translate the hole plugin would be much more nifty
but i don't wanna push you.
And i already learned french for this forum (ok, only a few words
wich i forgot yet again) from http://dict.leo.org/frde
but i will be ready to use your plugin first if this reached around version 13.01, maybe in the year 2525 ?
au revoir
stefan
As i said,
would be enought ?
au revoir
stefan
- Membre d'honneur
