Hi,
My suggestions are on Selection tool (the same for Magic wand tool).
It's very difficult to work with the tool as adding/subtracting from selection are not allowed.
I think if you use Shift/Ctrl buttons for that that would be great. Moreover,
the way to move/cope a selection is too exhausting. Better to add here keyboard keys as well:
when user clicks inside selection with a left mouse button and drags mouse and ALT key is pressed then the whole selection should be moved (cut and paste operations are done automatically in the background),
when user clicks inside selection with a right mouse and drags mouse and ALT key is pressed then the whole selection should be copied (copy and paste operations are again done automatically in the background).
Selection tools
- Membre d'honneur
