I use PhotoFiltre to edit my photos and I like to keep my original photos but I keep accidentally overwriting them by pressing the Save button
Change Save Button to Save As
arrowhead
- Version de PhotoFiltre : 6.3.1
- Système d'exploitation : Windows XP Home SP3
- Processeur : Pentium 4 3Ghz
- Mémoire RAM : 2Gb PC6400
Is there any way to make the Save button on the Tool Bar bring up the Save As dialogue instead of just saving?
ckit
- Version de PhotoFiltre : 11.7.0
- Système d'exploitation : Win11 Pro x64 25H2
- Processeur : AMD Ryzen 3 3300X
- Mémoire RAM : G.Skill FlareX 3200Mhz 16Gb DDR4
Re: Change Save Button to Save As
I support this suggestion!
you cans use SHIF+CTRL+S
quader
- Version de PhotoFiltre : 6.3.0
- Mémoire RAM : 1.25 GB
I agree. This is much needed. Either a Save As button or a confirmation with a chance to change the name (or both). It's too easy to get used to other applications that work this way and forget that PhotoFiltre is the exception.
