How can I write Thai language on image ???
samuraigirl
Version de PhotoFiltre : 6.3.1.0
Système d'exploitation : 6.3.1.0
Message par samuraigirl »
Hi there,
I am already long to Photofiltre, and I like it very much.
today I have update to PhotoFiltre Studio 9.2.1.0
why I get only Trial version limited to 30 day???
and every file I can´t open to another progarm???
and eny long time I try to write Thai language on image
but them only show like this ?????
help me please,,,
thank alot^_^
Plazzmex
Version de PhotoFiltre : 9.2.1
Re: How can I write Thai language on image ???
Message par Plazzmex »
the same for all other non english-compatible languages.
for me its the same problem for hebrew.
the question is why if it was supported before, now it isn't ?
The problem is not PhotoFilltre, but the compiler Delphi 7 !!!
Delphi 7 don't support unicode text in 16 bit like extended caractère (thai, chinese, hebrew, arabic). Only 8 bit caractères :cry:
Plazzmex
and there is no thing that we can do to support it ?
nothing ? any delphi extension or newer delphi version ? anything ?
p.s - Delphi 2009 will support full unicode.
yes, but i need to buy this version (not free) and modify all sources (not so simple :wink: )
