Suggestion for PF and PFS
Doug Bays
- Version de PhotoFiltre : 6.3.1 and 9.2.2
- Système d'exploitation : Windows XP Pro SP2+
- Processeur : Intel Dual Core 2666
- Mémoire RAM : 2048
Just wondering about the possibility of having a Crop Tool like the one in PhotoBrush by MediaChance.com. It seems so much easier to Zoom/Enlarge the photo to a rough crop size and just draw a line around your choice, make any minor adjustments and double click. The bright coloured lines are also advantageous on any background.
luxornet
- Système d'exploitation : win2000
- Processeur : 600Mhz
- Mémoire RAM : 256
Re: Suggestion for PF and PFS
*I don't like the Clone Stamp Tool because when I press Ctrl key an unpleasant stamp icon appear instead of the cross and I don't know which is the active point; I prefer a precise cursor here to easily select the desired point/pixel.
*Another problem is that I can't made multiple selections with SHIFT. Is there another option for this?
*It is very necessary a stand-alone crop tool; now I must press the 'Selection tool' (which icon is an arrow!!!!) then I must make a selection and then I must press SHIFT+CTRL+H (Image -> Crop menu)! Very complicate work for a simple job.
