Layer Help
KoriH
Version de PhotoFiltre : PhotofiltreStudio
Mémoire RAM : 1gb
Layer Help
Message par KoriH »
It seems like every program I use has a different way of handling their layers :shock: and it's starting to frustrate me. Granted it's 1 in the morning as I type this, but such is life.
All right, to define my problem better: I color alot of lineart, mainly because it relaxes me. Thing is, I use layers-formerly on photoshop, though I thought this time I'd give photofiltre studio a try. My problem, is that I always keep my lineart as the top layer, and use subsequent layers for certain colors or items as they sit in the lineart. Does PhotofiltreStudio support layer ordering-and if so where? I've looked for it, though I am still on a trial version.
If it doesn't support layer ordering, is there a chance it can be developed?
:) Sorry if that rambled, made no sense, or offended. I'm tired, and admittedly a little cranky.
-Kori.
Jaume44
Système d'exploitation : w7
Re: Layer Help
Message par Jaume44 »
Hi Kori............
Yes, PFS supports layer ordering. In the window of the layers, hold down the left click button of your mouse over the layer you want to order, and simply move it. It will not do this with your initial background layer, however if you duplicate the initial background layer, you may order the duplicate. I hope this answers your inquiry.........Jack :mrgreen:
THANK YOU SYMPHONIE...)
Dernière modification par Jaume44 le 05 janv. 2008 11:57, modifié 3 fois.
Symphonie
Mémoire RAM : 2 Go
Re: Layer Help
Message par Symphonie »
You mean left click I think, Jaume ;)
KoriH
Mémoire RAM : 1gb
Re: Layer Help
Message par KoriH »
Thanks Jaume, Symphonie. :) I greatly appreciate it. Hopefully I'll have something to show for that soon 8)
