About the eraser tool.
Message par About the eraser tool. »
Would you please tell me how can i find an eraser tool?
I really can't find that by myself.
An eraser without layers is exactly the same as a white paintbrush :)
In the Studio release there will be an eraser witch sets transparency on the current layer.
there is no eraser tool, but you can take the brush with white color and erase what you want...otherwise, you can select a part of your picture, right mouse's button and "erase"
Thank you!
Message par Thank you! »
Now I know how. Thanks for your patient explaination.
