I am using PhotoFiltre Studio 8.0.2 with a German language pack.
Today I opened a 1x1 pixel alpha transparent PNG image and tried to resize it. It did not work, but the following box appeared instead (which I don't understand beacuse I don't speak any Franch at all):
If I select a resizing filter other than <Automatic> (or <Automatisch> in German version), everything works, so I assume the error occurs when trying to determine which filter to use "automatically".
Thanks for translating this for me! Nevertheless, it mus be a bug since the box only appears when using the <Automatic> filter and a dimension of 120x120 pixels will hardly be too small or too large for a maximized 1024x768 window.
Is it possible because it is 1 X 1 pixel, it cannot be enlarged? You are probably much better versed with graphics than I, but it seems logical. Let me know. Thanks! P.S. I tried enlarging it as a flattened image; it worked, but when I tried with a tranparent image layer, I experienced the same result as you.
