export 16 x 16 ico (favicon) in PF Studio
Marga
Version de PhotoFiltre : PF and PFS
Système d'exploitation : W7
Mémoire RAM : 3
Message par Marga »
Hi all,
In the last update to 8..0.1 there is the possibility to export an image to ico (favicon).
This is where I hoped for since long.
But: where do I find this... :cry:
Image- Export does not give the possibility.
thanks for your help.
Love from Holland
marga
Benthai
Message par Benthai »
Hello...Marga...
I think you didn't try to have a look at the "tools" section....you'll find there..."export as an ico"
Best regards..
Benthai
Marga
Mémoire RAM : 3
Export ico
Message par Marga »
Thank you..... !!!
Love, marga
