- to use either one incident at a time
- or a continuous flow of that ONE graphic?
Click on nozzle, select the one you want, then click once in your canvas area.
Not the graphic you want, remove it (ctrl Z) and click it again.
Still not the one you want, repeat the procedure until you come to the graphic in the nozzle you want to use.
Now hold down ctrl and click each time you want that image, all the while keeping ctrl held down.
You want a continuous flow of that image, just hold down the Left mouse button while painting as with a brush tip!
You can also change the step interval and/or size per cent while working with that selected image from the nozzle. Neat, right?
If you should "lose it," just go through the selecting procedure again.
