Hallo,
how can I install the german Language-File into the Version 6.2.6 of Photofiltre?
Greatings
Andreas
PhotoFiltre 6.2.6
Waldy
- Version de PhotoFiltre : 6.1.2
Jepe
- Version de PhotoFiltre : PF 6.4.0 & PFS X 10.3.0 beta
- Système d'exploitation : XP SP3
- Processeur : AMD Sempron 3100
- Mémoire RAM : 1536 Mo
Waldy
x
Jepe
Hello "x",
Of course, first you have to install your PhotoFiltre by executing "pf-setup-en.exe".
After this, to unzip (or extract) the compressed "TranslationDE.zip" depends if you're working under Windows XP or an earlier Windows system.
In Xp you just have to right click - in Windows Explorer - on a Zip-file and you will see an option "Extract all". A click on this option will start the procedure asking you where to extract the files. Use the browse button to indicate the main folder of your PhotoFiltre installation and do "Next".
When you will start PhotoFiltre you should find it with German translation.
If your are working with an earlier Windows system you have to install first an ZIP-software as "7zip" (open source) or "Winzip" (shareware) to do this.
Hope I was clear enough and this helps you.
Jean-Paul
Jean-Paul
