Impossible to use the scanner
John
Hi,
Just starting to use Photofiltre.
The software is great but I have one big problem.
When I want to use my scanner the program closes.
Is this a known problem or what am I doing wrong ?
Thanks,
Thanks,
- Membre d'honneur
John
Hi,
I already did that.
If I select my webcam it's working perfectly,
but if I select my scanner (Mustek 1200CP) it closes the program without any comment.
Other programs like Paint Shop Pro work fine on this issue.
The scanner that I use has a parallel connection but I don't believe that this will be the problem or am I wrong ?
Thanks,
I already did that.
Thanks,
- Membre d'honneur
John
- Membre d'honneur
John
- Membre d'honneur
John
- Membre d'honneur
If you try with Antonio's new plugin here, does it work ?
