Transformation text in PF and PF Studio
Marga
Version de PhotoFiltre : PF and PFS
Système d'exploitation : W7
Mémoire RAM : 3
Message par Marga »
Hi all,
I am looking for the possibility to transform a text in PF Studio like I used to do in PhotoFIltre.
I always do it so in PhotoFiltre: picures in French... sorry
1. Make the text
2. Comfirm (apply?) it
3. Make the selection again
4. Go to Edit -Transform - Distorsion;
5. Then it comes like this:
But... HOW can I do this in PF Studio...???? Where is the Transform- option...??? I use version 7.4.0
Love, Marga
Menu Claque > Transformation
Marga
Mémoire RAM : 3
transformation of text in PF Studio
Message par Marga »
Thank you, I just found out that you have to convert the textlayer into a picturelayer... then it works! :D
Love, Marga
