How to compress TIF-Files
Richard
Message par Richard »
Is in PhotoFiltre to modify the compression TIF-files?
Or can I use u plugin?
After saving TIF-Files with PhotoFilter they will be
very big! (24 MBs or so)
Saving them with IView reduces them to 300 kb.
Cu
Richard
Benjamin
Version de PhotoFiltre : 6.0
Mémoire RAM : 512Mo DDR 333
Message par Benjamin »
There is no LZW compression for the moment...
delphiuser
Version de PhotoFiltre : 6.0.2
Processeur : PIII 1GHZ
Mémoire RAM : 128 Mo
Compress Tif Files
Message par delphiuser »
Hi,
As said Benjamin, You can't compress Tif Files in Photofilter :oops: .
But You can save the file in a different format as JPG With a good Compression :D ...
OK!!
delphiuser
Invité
Re: Compress Tif Files
Message par Invité »
[quote="delphiuser"]
Hi,
OK!!
Well, your're right!
But there is no better compression for black/white pictures (like text) than TIF...
Richard
you can use GIF or PNG, this format use LZW compression like TIFF
sioboop
Système d'exploitation : Win XP Home
Message par sioboop »
Hi! New here, I just love this program!
Can you tell me how to compress a GIF file from 16mb to 15mb?
Antonio a écrit :you can use GIF or PNG, this format use LZW compression like TIFF
Thanks,
sioboop
You can't... A GIF is always compressed... By default !
sioboop
Ok, thanks. Then my question is, how do I make the file smaller? I need to make a banner that is only 15mb and my design is 16.6mb. Any suggestions?
FrançoisL a écrit :You can't... A GIF is always compressed... By default !
Use color reduction (128 or 64 colors)
15 Mb, this is a bit heavy for a simple banner, isn't it ? :D
sioboop
Thank you Antonio, I will try that.
Francois, the banner ad is 120 x 600. Kinda big. I am on Tribe.net and they have offered to let us send in a banner to advertise our tribes during January.
Oops! and it is 15KB not MB sorry!
