how do I make paste special become highlighted?
Carole Alexander
Système d'exploitation : Windows XP Home
Message par Carole Alexander »
Hi All
I copied and pasted 5 pictures together for a heading which was great!
However, when I attempted to make another heading I couldn't because
the 'paste special' is not highlighted.
Does anyone know what I must do to clear it/unfreaze it ?
Hi Carole,
Is your image in good mode? :
Image > Mode > RGB color
Carole Alexander
Hi Patrick
How do I get my image in good mode? :
I just checked the image on photofiltre and have no idea how you do this.
Carole
Carole Alexander
I've tried this!
Thanks for the close up :lol:
Patrick, I have done this.
I bring up the photo I want to use, click on image and then 'mode' isn't highlighted :shock:
How do I unfreaze this?
Carole
Hi Carole,
Menu Image/Transparent colour/Disable transparency
FAQ :wink:
Tu m'as grillé la politesse Tom! :)
Carole Alexander
Hi Tom
I realize now what the problem is.
If I do as you say then the background of these images re-appears.
I don't want this to happen. I want them (the flowers) not to have a background.
Maybe it's impossible to join images together unless they have a background.
Thanks a lot for trying. :)
All the best
Carole
Carole Alexander a écrit :Thanks a lot for trying. :)
I'm sorry but you invert the places. :lol:
I think properly you could try a little more. :wink:
There is no problem to copy a picture in indexed colours or containing transparency.
But to paste, there is no way to do it on a such picture without background.
You have to chose a background colour rather different those of your pictures.
Any way, when your work is done, you can select the background with the magic wand and do :
menu Image/Automatic transparency/Inside selection
so you have again a picture in indexed colours with transparency.
If the result is not which you wish, don't forget the undo button. :wink:
Désolé Patrick,
je n'ai pas pu m'en empêcher. :wink:
Carole Alexander
Voila!
Naturellement ! :) Voila !
Beaucoup de mercis Tom.
Tom a écrit :Désolé Patrick,
Ca tombe bien, ton anglais est nettement meilleur que le mien! :wink:
Carole Alexander
Patrick, votre anglais est très bon :)
Thanks Carole! :oops:
