Buon giorno,
uso Photofiltre dalla versione 7 e da allora ho usato scanner HP, Lexmark, attualmente Canon e mai sono riuscito a scannerizzare con i driver proprietari in Photofiltre. Vi è noto il problema? Grazie Augusto Tironi
Good morning,
use Photofiltre version 7 and since then I have used scanners HP, Lexmark, Canon and currently are never able to scan with the proprietary drivers in Photofiltre. As you know the problem? Thanks Augusto Tironi
Scanner
Re: Scanner
PhotoFiltre is bugged with some scanners. I think it is a twain compatibility problem.
Check you have the last twain drivers for your scanner. Some times it fix the bug
- Version de PhotoFiltre : 10.10.1
- Système d'exploitation : win 10
- Processeur : i-7
- Mémoire RAM : 8gb
Re: Scanner
Currently the problem is manifested by Canon MP280 Multifunction; with other software, there are no problems.
Thank you
Augusto Tironi
Thank you
Augusto Tironi
