Photofiltre toolbar icons size
sas2000
Is it possible to add an option in preferences to increase the size of Photofiltre toolbar icons ?, with high resolution monitors these icons looks quite small, an option to increase the size of tools palette icons would be great too, thank you very much
Mészáros Tamás
- Version de PhotoFiltre : PhotoFiltre Studio 10.13.1
- Système d'exploitation : Win 7 Home Premium SP1
- Processeur : AMD II X2 Athlon 265 3.3 GHz
- Mémoire RAM : 8 Gbyte DDR3 2133 MHz Predator Kingston RAM
Re: Photofiltre toolbar icons size
Hi!sas2000 a écrit :Is it possible to add an option in preferences to increase the size of Photofiltre toolbar icons ?, with high resolution monitors these icons looks quite small, an option to increase the size of tools palette icons would be great too, thank you very much
System settings -> monitor so to increase the dpi settings text size settings. 100% -> 125% or 150% or Hi-Contrast appearance. Nothing else. When to use above monitor Full HD resolution.
