Photofiltre program in win 7. I installed this program on my new laptop, been using it for years. I've been using it on XP on my old LTop, now I have a new Ltop that has win 7I guess I'm not familiar with win 7 as I'm having a problem making it the program I want to display all of my photos.
All I had to do in XP, was right click the thumbnail, select open with, browse until I found the program, highlite it, check the box that said use this program to open .
I have basically done the same steps as above, rite click, open with, paint, win media center, win photo viewer, choose default program.
I then select, choose default program, then browse, a box comes up with a list but photofiltre is not on the list. I know the program is in my computer, but I don't know how to get it to that box to select it. I tried dragging it but that didn't work.
Any help on this greatly appreciated.
When I go to all programs I can see that photofiltre is there, I just don't know how to get it to that dialogue box.
I am so lost without this program...please help
I can't make this program my defualt
raycer27
- Système d'exploitation : Win 7 professional
Mészáros Tamás
- Version de PhotoFiltre : PhotoFiltre Studio 10.13.1
- Système d'exploitation : Win 7 Home Premium SP1
- Processeur : AMD II X2 Athlon 265 3.3 GHz
- Mémoire RAM : 8 Gbyte DDR3 2133 MHz Predator Kingston RAM
Re: I can't make this program my defualt
Hi!raycer27 a écrit :Photofiltre program in win 7. I installed this program on my new laptop, been using it for years. I've been using it on XP on my old LTop, now I have a new Ltop that has win 7I guess I'm not familiar with win 7 as I'm having a problem making it the program I want to display all of my photos.
PFS my not set as the default. This is not problem. Because PFS is pitcure editor, not only picture viewer. PhotoFiltre Studio photo editing, so there is no need to do so. Tools -> Options -> Save -> Default Formats [pfi]. This is more than enough for the Start menu fixing.
Best Regards:
