Photofiltre 6.5.2 Frozen
Shinnen
Processeur : Intel p4 2800mhz
Mémoire RAM : 1.5 gig
Message par Shinnen »
Hi,
Photofiltre has frozen. I had pasted a selection of the picture to another area, and was transforming to make it fit. I couldn't get it to fit, so I clicked on it to cancel, and got no response. None of the rest of the program responds either, except for the menus. It wouldn't be a problem except that I've done a lot of work on this picture, without backing it up, unfortunately. Is there any way I can save what I've done, or unfreeze Photofiltre?
Thanks,
..... john
Shinnen
Re: Photofiltre 6.5.2 Frozen
Oops........ my mistake. It turns out that I hadn't closed the the transform window.
Sorry..
..... john
