shows the draw not sharp while editing in the main window
trunix
Message par trunix »
_________________________________________________
the print and the result is ok, put while editing in the main window
PF Studio 10.7.3 shows the draw not sharp. so I have to zoom always
to see the accuracy of lines and edges.
Is this normaly with this prof version?
(because it was not happend in the free version)
Thanks for help or a note where I have to change this in the settings.
kind regards trunix
Re: shows the draw not sharp while editing in the main windo
Hi trunix,
menu View / Antialias. Works when the image is displaid with a zoom smaller than 100 %. ;)
