Hello out there, I am new to Photo filtre 6.5.1- and I have 2 questions.
Is there a tool in this program that will erase pixels (similiar to the eraser in Windows Paint) and if not is there a plug in?
Is there a tool or a way to get rid of 'red eye' in people and also 'white eye' in pets? or a method to do it?
mindy
eraser tool and red/white eye
- Version de PhotoFiltre : 6.5.1
- Processeur : ?
- Mémoire RAM : ?
Re: eraser tool and red/white eye
Hi,
- you don't need any eraser on this version, just use the paintbrush tool with the background color and right clic to drag and draw.
- on the PhotoFiltre 7 version (freeware) you can stack up some sheets as layers and use an eraser tool to draw transparency through the layers.
- there are two plugins to fix red eyes you can find them on the official site of PhotoFiltre at the plugin's page.
- Processeur : ?
- Mémoire RAM : ?
Thank you for your quick reply and info. will get the downloads - Mindy
