Image Explorer to show only thumbnails of currently opened f
goforit
Message par goforit »
When I click on the Windows menu in the toolbar, I see a list of file names for the photos that are currently opened in PhotoFiltre. Clicking on one of those names brings that photo to the foreground. Is there any way to change the view from file names to thumbnail images to choose from?
The “Image Explorer” feature does not quite do this, either. It will show thumbnails of all the images in a particular directory, but not just the currently opened images (which may come from a number of different directories). The only way I can see to do this would be to open all the images of interest and then resave them all to a single directory. I would then direct the image explorer to that new directory listing all of the photos currently open.
I could do this with Dell Image Expert, which, unfortunately, does not run in Windows 7.
Re: Image Explorer to show only thumbnails of currently open
Hi Goforit,
did you try to uncheck "Maximize window when opening" in the View menu ?
Because after this action, you can display all your opened images in the PhotoFiltre's workspace
by the "tile function" in the Window menu.
