Adjust "old"text > how to choose same font?
Nico1096
Message par Nico1096 »
Hello,
I make my own cards.
And sometimes "refresh" the text by adding new items.
Would like to do that in the same font as the other text.
But without success.
Q: how can I get the same font?
I tried:
- make new text line
- changed font in Options Text
No result.
Hope to hear from you.
Nico
The Netherlands
Re: Adjust "old"text > how to choose same font?
Hi,
PhotoFiltre uses the fonts which are installed in the windows system. :)
So, if you change your computer, you should keep a set of the fonts you wish re-use.
For information : the Studio release (shareware) allows to save in pfi format a picture file
which contains the layers of your work, but the problem is the same if you have'nt kept the right font.
On some fonts web sites i think you should find the right one and download it.
A little request in a good research engine ...
Nico1096
Hi Tom,
Thank you for your swift reply.
I tried to follow your advice.
But without result.
However, by coincedence I found the website http://www.oudje.nl
with numerous advices in Dutch(!).
First thing I did was upgrading my PF version from 6.1.4 to 6.4
Et voilá, I can adjust "old" text with same font!!!
Thank you once again.
Nico
The Netherlands
Et voilà, with an upgraded version it's magic. :D
Fine, i'm glad you have found the right issue.
Have a nice entertainment with PF. :wink:
