1 It should be possible to type or copy a path;
1b or even to draganddrop from WinExplorer
2 The output path should default to the Input path, to be edited
2b or maybe to a (parametrizable) standard suffix of it,
e.g. if input is specified as c:\photos\playa
output could default to c:\photos\playa\vignettes
(which can be accepted or edited)
batch processing: path entry should be easier
jfd
- Version de PhotoFiltre : 6.3.2
- Système d'exploitation : Vista Pro
- Processeur : Intel double
- Mémoire RAM : 2 Go
Re: batch processing: path entry should be easier
don't forget you can save your settings, don't need to set every time your folders
