Alphatransparent Resizing Glitch & More Bugs
Pac-Man
Message par Pac-Man »
I don't know if some of the bugs were mentioned already in these forums (I sadly do not speak French). But these problems of PFS sometimes cause me to use other programs like Paint.NET :(
1.
If I resize an alphatransparent image to a smaller size, some pixels at the border of the image get more opaque than before (colors from the background of the alphatransparent background) get added. This makes the picture look ugly and unusable.
Here is a picture of what I mean:
2. You cannot copy the webcode of a picked color into the clipboard with Ctrl+C! I always have to right click and choose "Copy", of course this isn't a problem, but a nasty workaround.
3. PFS can't open some bitmaps or PNGs (I will upload such a bitmap later), but Microsoft Paint has no problems with it. PFS than spams me with hundred of error messages before I can close it :shock: .
Re: Alphatransparent Resizing Glitch & More Bugs
if I resize an alphatransparent image to a smaller size
==> use the menu Layer > border effect > antialias or blur to fix after resize
==> send me a png image for example
Pac-Man
Thanks for your fast reply.
But whenever I apply the border effects, some parts of the image get lost. Especially text looks "rounded" then.
The files PFS can't open are placed here (you can greatly open them with paint): http://cid-d52043ae75c1d239.skydrive.li ... cprobs.zip
The first ones (???format.*) are saved with .NET libraries. I don't know if they mess the header or something, because I do not know how they are saved. The file with the name "gameshot" was made from a game (if you try to open it, PFS goes crazy. Keep Enter pressed to avoid the error messages). Some images can be shown in PFS, some only with MSPaint.
Your extension are not correct. PhotoFiltre need correct extension because i don't check the format in the file header but in the file extension.
For exemple your bmpformat.bmp is a PNG image and must be named bmpformat.PNG.
The gif is a tiff and some jpeg are PNG. In this case it's not possible to open it with photfiltre :cry:
Pac-Man
Antonio a écrit :Your extension are not correct. PhotoFiltre need correct extension because i don't check the format in the file header but in the file extension.
That is weird. I am pretty sure my program didn't cause that bug :D but I will check the code. Thx for the info.
liyo
Version de PhotoFiltre : 10.1
Processeur : Pentium 4 HT
Mémoire RAM : 1.5GB
Message par liyo »
Hi Antonio, please please fix CTRL+C bug :|
Thanks great program :clap:
Pac-Man
liyo a écrit :Hi Antonio, please please fix CTRL+C bug :|
I guess it is caused by a shortcut used by another tool which uses C.
CTRL+C is a global shortcut to copy the image :wink:
liyo
Mémoire RAM : 1.5GB
Message par liyo »
Would be nice to customize keyboard shortcuts or avoid it when cursor is focused on webcode color :)
PD: version 9.2 doesnt have this problem
Thanks for the fast reply!
Mészáros Tamás
Version de PhotoFiltre : PhotoFiltre Studio 10.13.1
Système d'exploitation : Win 7 Home Premium SP1
Processeur : AMD II X2 Athlon 265 3.3 GHz
Mémoire RAM : 8 Gbyte DDR3 2133 MHz Predator Kingston RAM
Message par Mészáros Tamás »
liyo a écrit :Would be nice to customize keyboard shortcuts or avoid it when cursor is focused on webcode color :)
I think this problem...Windows 7 bug preediton - Windows 7 realised 2009 october :oops:
I cleened my code for this new version, perhaps i cleened too much, i will test...
