Hi all
Haven't found this in FAQ:
JPEG2000 plugins are working fine.
When i associate JP2 with PhotoFiltre, i get an error msg because the JP2 format is not directly "understood" by PhotoFiltre.
Is there a workaround to make PhotoFiltre load the JPEG2000 import plugin when doubleclicking a JP2 file?
Thanks in advance.
Markus
associate with extension of import plugin
- Membre d'honneur
