Dear Friend,
could someone design a plug-in to add and to extract a watermark to/from a digital photo ?
Thank you
Add / extract a watermark to a photo
lillo
Jaume44
- Version de PhotoFiltre : Studio 10
- Système d'exploitation : w7
- Processeur : Pentium (R) Dual Core
- Mémoire RAM : 4 GB
Water Mark
Hello Lillo,
You may add a watermark utilizing the text tool, selecting the ideal font, and fade option of the text tool. If you are using Studio, you may also convert the text layer to an image layer and add various touches, such as progressive contour...using a large font size then reducing the size.
I hope this is of some help and use.....Jack
