Hi,
I've been having a look around but i cant find many places with brushes or nozzles that I like, I'm afta a few things like:-
Horses, Butterflies, Hearts, Stars the usual girly stuff and some I saw a while ago but lost on the computer were some babies but in the palms of peoples hands. Does any one know of some sites please?
~Sunsparkle~
I'm looking for...
Sunsparkle
- Version de PhotoFiltre : 9.0.0
- Système d'exploitation : Windows ME
Sunsparkle
Thanks
Thanks slyvie, that was the forum i was looking for but I can't understand much french
so i couldn't find it lol. Thanks again.
~Sunsparkle~
~Sunsparkle~
Jaume44
- Version de PhotoFiltre : Studio 10
- Système d'exploitation : w7
- Processeur : Pentium (R) Dual Core
- Mémoire RAM : 4 GB
Sunsparkle
I dont know how
Hi jack, as to makinh my own brushes and nozzles, im not sure how to, what format do I need to make my own?
carlo taradel
- Version de PhotoFiltre : PF-PFS
- Système d'exploitation : win XP pro- ubuntu_ breeze
- Processeur : recycled from waste bin
- Mémoire RAM : 1026
Png ...for the brush you need to make them as square in stripes (usually from 100 to 200 height put not border in between and save in PNG
I'm not very sure about the nozzle i'm sure there is a tut in french...but maybe its automatic translation will make no sense.
However i think they are done as the brush in png format
carlo taradel
Jaume44
Sunsparkle,
The following is advice and directions graciously given me by Tom:
no real tutorial until yet, but .... i have picked up several tips :
- square format as 100x100 pix or 400x400 Max upon a white background
- create a first picture convert in grey scale 256 colours. No transparency.
- create a second picture with the same attributes, copy
- on the first picture : special paste/ assemble the paste on the right
and so on, for the other pictures. Maximum size for the total width 2000 pix
- save the result in png format
I hope this is helpful. When you follow the above instructions, place the finished design in the brushes folder in your PhotoFiltre program folder.....
