forced TIF LZW
mangels9
forced TIF LZW
All .tif files that I save with Photofiltre are compressed LZW. How can I save them as an uncompressed TIF.
Jaume44
- Version de PhotoFiltre : Studio 10
- Système d'exploitation : w7
- Processeur : Pentium (R) Dual Core
- Mémoire RAM : 4 GB
Tiff Save
When you are saving the .tiff in PF Studio 8.0, you should have an option window pop up giving you the choice of unchecking "compression." I hope this helps.
mangels9
Jaume44
Perhaps
While you do not have access to PF Studio, perhaps you might save your image(s) to a folder in a high resolution .bmp, and later, if you have another software for saving, resave it in .tif uncompressed. ??? Of course, Studio is lots easier. I have kept my original PF and I also have PF 6.2.6, no special reason, just sentimental I suppose. I do find lots of use for PhotoFiltre 6..........I hope this has been of use to you.
mangels9
