Studio crashes!
guruerne
Studio crashes!
Message par guruerne »
Hi!
When I use the feature to "open as layer" (layer - new - open as layer), the program crashes when I try to open the 3. layer.
I've tested this on several machines - they all do exactly the same!
(both v. 7 and v. 8)
Solutions??
:) Erik
Jaume44
Système d'exploitation : w7
Crashes
Message par Jaume44 »
Hello Guruerene,
I have just executed a graphic in PF Studio. I placed six layers utilizing the option of "open as layer." It functioned perfectly for me. I was working on a canvas at 800 X 600 pxls at 72 dpi, if that is of any help. I was using some three color banner-type graphics. If you do not get satisfaction here in the Forum, send a note to Antonio da Cruz at the contact option on the PS website. I am sure he will get right to the bottom of the problem.
Jack
guruerne
V. 8.0.1
:oops: Maybe it's because I was using the 8.0.0 version of PhotoFiltre-Studio. I just updated to v. 8.0.1 - and now it seems to be working just fine.
Thanx for your answer - I will test the program some more, and hopefully I'll find no bugs :) :)
Regards
Erik / Guruerne.dk
no ! tell me your windows version and your memory ?
guruerne
V. 8.0.1 did the job!
I have
Amd 64 3400 processor
Win XP pro (original!)
1 gb ddr2-memory
I've had 2 teachers test as well - the 8.0.1 do NOT crash
when using "open as layer"!
So - the update did the job, problem solved! :)
Regards -
Erik / Guruerne.dk
did you read this post :
viewtopic.php?t=7296
PayPaul
Version de PhotoFiltre : 9.0
Système d'exploitation : Windows XP Media Center
Processeur : Athlon 64 X2
Mémoire RAM : 2GB
Re: Studio crashes!
Message par PayPaul »
I was resizing an image when it suddenly decided to stall. I was looking at the resampling portion of the dialog box and put it back to automatic. I clicked OK but the box refused to close. Now the program does not shut down but I can't access menu items to save my file. What's going on here?
System Info:
System Manufacturer HP Pavilion 061
System Type X86-based PC
Processor x86 Family 15 Model 75 Stepping 2 AuthenticAMD ~2204 Mhz
Total Physical Memory 2,048.00 MB
Available Physical Memory 1.41 GB
Total Virtual Memory 2.00 GB
Available Virtual Memory 1.96 GB
Page File Space 5.75 GB
Thanks,
Paul
Re: Studio crashes!
Some times with big images, dialog box are locked in StayOnTop mode because the process message link between Delphi and windows was brocken. This bug is fixed in the next 9.2.0 (release for april 2008)
Mészáros Tamás
Version de PhotoFiltre : PhotoFiltre Studio 10.13.1
Système d'exploitation : Win 7 Home Premium SP1
Processeur : AMD II X2 Athlon 265 3.3 GHz
Mémoire RAM : 8 Gbyte DDR3 2133 MHz Predator Kingston RAM
Re: Studio crashes!
Message par Mészáros Tamás »
PayPaul a écrit :I was resizing an image when it suddenly decided to stall. I was looking at the resampling portion of the dialog box and put it back to automatic. I clicked OK but the box refused to close. Now the program does not shut down but I can't access menu items to save my file. What's going on here?
System Info:
Thanks,
Paul
Hello!
And please use you original Windows theme...another Windows theme lot of problem. :!:
:idea:
Best Regards:
